RSView32--Displaying 'Short Tag' Property
cntrlfrk
Feb 2006
Nebraska
244
I noticed in the RSTrendX Properties in RSView32 that you can choose the pen caption to be 'Description/ Short Tag/ or Long Tag'.
Does anyone know a way of displaying the "Short Tag" on a normal display?
I'd like to display this on a faceplate, so, when I'm troubleshooting something over the phone or otherwise, I can quickly see what the tagname is in a RunTime application. I've thought about going through and putting in ToolTips for this, but it would be much easier if I could use a parameter file since most tags won't fit on a faceplate since they look like:
Plant_1\Steam\Boiler_1\Pressure\PIC001PV
and I would like to just show 'PIC001PV'
create a memory tag (eg TEST) of string with initial value of PIC001PV
add a label to the popup
give it a parameter link (eg #1)
in the parameter file
#1 = TEST
Hi, I want to display a string tag in the alarm log file in RSView32 works. For exapmle, in the user custom message in the "Alarm States" tab I...
5,173
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
397
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,926
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
609
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,452
