Running RSView32 Project from a CD
iknowsomeplc
Apr 2002
USA
199
Hi all,
Is it possible to run RSView32 project from a CD? I understand that some files/folders should not be read-only while RSview project opens.
My requirement is to autorun a project on a CD when I distribute the CD. If at all some files to be transfered to temperory folder in hard disc , how can I assign the changed path in RsView project file?
I understand that the path information is stoed in the *.rsv file , but when i open in notepad /word , i found some junk characters and afraid that the editing this file will help only for a particular file , for a different project , i donno the file format to edit.
Any ideas? Anybody did some research on this earlier?
Do you plan on having an "activation key" on each of the PC's that will be running the RSview?
It might be possible, but very difficult (and possibly illegal) to manipulate this file from a CD.
Hi Good people i have made some adjustments to a project and i would like to run it on the laptop before i put it on the machine. i am using...
2,355
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
171
How to fix if appears code “$115 plc-restart running” on the screen OP17
271
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
373
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
118
