[S5-155U CPU948]HEX convert to Integer ??
apple
Jun 2006
Taipei
24
This code's comment say it can convert Hex number to Integer number, but I don't understand how it work, wish you can explain it. Thanks!!! Thanks!!!
Input in FW250 with Hex number and Integer number in FW248
Here the code:
L FW250 inhalt der adresse IN [KH]
SLW 8
L FW250
SRW 8
OW
T FW248 inhalt der adresse IN [KF]
The code is swapping bytes, changing High Byte > Low Byte and Low Byte > High Byte.
I presume FW250 holds a KF format number thats been read in with the bytes swapped. This sometimes happens.
Apple,
I don't think you are "converting"...word 250 and 248 can be view in hex or as a integer that is where the [KF] and [KH] come in, you are just viewing them different, as Peter has said SL Shift Left and SR Shift Right
inhalt der adresse IN [KH]//contents of the address IN [KH] HEX
inhalt der adresse IN [KF]// contents of the address IN [KF] (K)constant integer
Peter am I correct in this assumption?
Also look at this CPU 948 it may have some info that will help..
I was going to say the same but noticed it was just byte swapping.
I know that some SCADA/HMI systems sometimes require byte swapping, had to do it recently with data received over serial comms from an X-Ray machine.
i have an old PLC : S5 155U (CPU 948) i need to connect it to ABB PLC using Profibus-DP, ABB will act as Master and S5 as slave. I need to...
3,012
Iam new to siemens systems and trying to install S5-155U CC with a CPU 948 in a very old plant.The CPU is OK and RUN LED is Green and iam able to...
1,449
Hi! Everyone~ I want to know is there some way can copy program code from one cpu to another cpu, and append it? My system has two cpu948, A and...
2,215
Hi~ I have a question about Intouch. this is,could Intouch directly read/write date(DD,DW,I,F...etc) from/to PLC via H1Server? assume all setup...
2,389
Hi~Everyone,I don't understand what mean this code, need your guys help, Thanks!! I have two FX block(FX131 and FX132) ,they call the same...
2,676
