S5 timers with compares?
russg
Aug 2012
UK
280
I'm more used to using S7 and been given an S5 project. Does anyone know how a compare is used when say T21 is input into one of the inputs?
The pic is from the program. I'm assuming it means when T21 gets to 3 seconds it will output A5.1?
Can anyone confirm this please?
Thanks for the info Garry. I would have thought entering T21 would just give you a high or low signal ie 1 bit? I would have thought using the actual timer value would mean having to use the BI or BCD out functions of a timer?
In STL it's like this:
LC T 21; Loading the timer value BCD coded
L T 21; Loading the timer value as integer.
I mean to remember that the timers counts downwards to 0.
Edit: Ad KF+3; the size is dependant of the time base of the value loaded when the timer was started. So it can be 3*10ms, ... to 3*10s.
Kalle
He's not correct; !=F means "not equal to" so at the moment the timer value is 3, the output is off. also the timer probably continues after that depending on it's setting.
second, what's your purpose posting links to your local drive? lol.
from the manual
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
530
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
400
I'm writing some alterations to an FPWin program and need to see the running value of timers so I can set them correctly. It's my first time with...
146
Hi everyone I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the...
622
Hi all, I have what is likely not a complex issue, but I am working in Automation Studio and want an accumulating/retentive timer when a...
17
1,951
