S7 1200 HMI No forced screen change
HJTRBO
Jul 2008
Melbourne
618
Hi, I can't force a screen change from the PLC on a KTP600 HMI. The help lists the "current screen number" array element as (PLC) read only. That really bites some big d@#k.
I have tried to write to from the PLC but the HMI (obviously) ignores the written value.
I'm just wondering / hoping if i'm wrong?
NP
I dont use S71200 or the "Basic Panels" but if you are refering to the area pointer "Screen number" it will be read only.
Usually you create a screen force tag (INT) and then in the Tag properties use "ActivateScreenByNumber" in Events/Change Value then assign the screen force tag to it.
Do you have this available in your function list?
I believe the model you are using is very limited i.e max 128 tags,no logs,Clock etc
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
724
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
164
I've got TIA portal v18, KTP1200 HMI. I want to add a slider bar (if that's the correct name for it) to an HMI screen. Baslcally, like a...
1,142
See the attached pic ("workflow"). I want to create 2 workflows, depending on if the person who's just logged in is an OPERATOR or an ADMIN...
17
2,483
Hello, I have a small application with a S7-1200 CPU 1212 and a KTP400 Basic HMI. When i am connected to the PLC with my PC i would like to...
547
