S7-200 PLC communication problem
johneedw
Oct 2009
asia
204
Hello Friends,
I'm facing a communication problem between the PC and S7-200 PLC(CPU 226) via Micro/WIN software and USB-MPI adapter, the settings are shown in the attached images.
Please ,check the settings and advice me about the error which cause the PC don't communicate with the PLC!..
Waiting for kind help..
Note: The PLC has two (RS -485)communication ports (port 0 & port 1)and i've tried the two ports with the MPI adapter but the communication still fail !.
IMG_20151122_112841.jpg IMG_20151122_112918.jpg IMG_20151122_112955 - Copy.jpg
S7-200
Dear John,
The communication protocol for the S7-200 is PPI, so you have to chose PC Adapter PPI not MPI.
Best regards
Hagos
Dear Hagos,
Thank you for kind reply, but some of MPI adapters is supporting PPI protocol and i've communicated with many s7-200 plc via MPI adapter !..
Is there any other reason plz?..
S7-200
Yes John,
You are right, you can use your PC adapter to access the S7-200, but you have to chose PC Adapter PPI instead of PC Adapter MPI.
You know that you chose it in the menu SET PG/PC INTERFACE
Regards
Hagos
Thank you very much dear Hogas, i've choosed PPI protocol and then PC communicated with the PLC successfully.. Thank you very much.
Best regards
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
3,161
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
436
Dear Experts, Good day I have to make ethernet communication between S7-1200 ( 1215c) and Beckhoff PLC CX5010. My question here any expert can...
4,328
Dear Experts, One of my client using S7-300 Plc In that Cp343 Module also using for scada and hmi connection ...
6,895
Hi everyone, i am working on a project S7 200 plc communication with KTP400 basic PN Panel.i am using a S7 200 plc cpu 224Xp and HMI...
3,944
