S7-300/400 SCL Shiftregister with strings
Kasperv79
Mar 2012
Copenhagen
48
Hi.
I tryid to make a shiftregister with 31 entry's.
the string array are declared in the Static area of the FB.
When I run the code its not every strings/date's are moved... :/
as you can see here: (22/03/2016 is there twice and from 12/03/2016 nothing is moved)
I did modify all the dates to be correct before run the code.. after som says i saw there was i problem..
//Kasper
Skærmbillede 2016-04-01 kl. 08.41.04.png Skærmbillede 2016-04-01 kl. 08.40.23.jpg Skærmbillede 2016-04-01 kl. 08.45.30.jpg
No more help needed :)
I changed the code into a Loop and replaced with BLKMOV instead.
Hi.
//Kasper
Hello everbody out there. I have 2 topics actually I wanted to share and get your opinions about but since they are related I sum up in one...
9,825
36
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
181
Hi guys, I'm having problems converting WinAC (WinLC RTF F application) to S7 300 project based on CPU 319F-3PN or S7 400/416F-3PN. The problem is...
617
Hello All I hope you are well and safe. I have a problem that I could use your appreciated input for: SW: SIMATIC MANAGER v5.5 SP3 HW1...
1,230
