S7-300 S7-400 communciation performance
Plc_User
Dec 2005
Belgium
317
I know for bigger installations the backplane bus is the bottleneck for the S7-300.
When having a lot of Profibus slaves (with a lof of communication per slave) connected to the online DP-interface Profibus cycle times can rise to high levels (one of my installations has 30ms, measured with diagnostic repeater, which I find too much). Dividing the network into two or more networks by adding a profibus mastercard in the rack would reduce the load per network and thus also the cycle time. But in case of a 300 controler maybe the new bottleneck will be the backplane bus. Maybe the effective time between transferring a value in the plc-programm and the receive in the Profibus slave migth be longer then when only using the integrated DP-master. I suppose that for a 400-controller that backplane load is neglectable.
What are your experiences, advices with using Dp-master cp's in a 300 or 400 rack and communication load, speed?
51
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
183
Hi guys, I'm having problems converting WinAC (WinLC RTF F application) to S7 300 project based on CPU 319F-3PN or S7 400/416F-3PN. The problem is...
618
Hello All I hope you are well and safe. I have a problem that I could use your appreciated input for: SW: SIMATIC MANAGER v5.5 SP3 HW1...
1,231
Hi What stage of its life cycle, S7-300/400 controllers are at now? In my existing unit, we are using these controller and in near futher there is...
7,103
