S7 300
Damilare
Oct 2011
lagos
Having a problem with establishing a connection with simantic S7 cpu which is loop through a profibus cable to the slave. Please help?
I think you need to give more information.
Is the network: 1 plc - 1 slave?
Has the connector of the plc only one cable? If so: check if the cable goes into the correct entry-point.
Is the terminating resistor active of not?
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
113
120
282
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
67
81
