S7-313C - Input/Output problem
supporter
Mar 2006
Malmö
167
Hi Guys,
This is a very basic question for experienced Siemens programmers (normally I program Mitsubishi PLC's). We have a Siemens 313C-2DP CPU with integrated Inputs/Outputs (DI16/DO16). When I create a project I see that the inputs are assigned IB124/125 and QB124/125.
The problem is that I want to monitor one of these inputs (using a VAT-object). If I set the input (using 24 V on the input pin) the LED is lit. However, when I monitor I124.0 (or IB124) the change of the input is not detected. What am I doing wrong?
Any suggestions are greatly appreciated!
Hi Weo,
No, M is connected from the power supply to M on the card. The LED is lit so it seems to be OK, or?
Any other suggestions? :)
1. Open HW config in online and look to IO.
2. I amn't sure but it seems I had similar problem some years ago. I amn't sure can be input visible as Ix.y if it's assigned to positioning or counting. Unfortunately, I cann't remember now details.:(
What do you see in HW online monitor/modify? There you can see physical input status. Did you applied 24V to another inputs belonging to this PIB?
Did you click the 'glasses' button to go online? The status window should strobe green and read online or something similar.
Right click to your DI24/DO16 in online HW config. Select Monitor/Modify. You can see PIB state when I/O display is checked.
hello i have 6ES7 313-5BF03-0AB0 and i need to make a smal regulation programme i have PT100 3 wires, to make it in inpute and output for a...
21
3,907
Hello everybody. I have got a tanker where we have a 313C running the safety system on the propulsion engine. The engine has a pick up which is...
4,125
Dear all, any one can you please send me an example programme in S7 300 plc in which 2 analog inputs are read and compared with a preset value (...
14,374
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
153
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,756
