S7-400 not comminicate Cimplicity
ashwinmori
Aug 2015
silvassa
I have no experience of cimplicity.
I have Siemens S7-400 PLC with GE Cimplicity SCADA.Unfortunately PLC not communicate with cimplicity .My communication method is PLC side MPI Computer side Siemens CP5611 A2 profibus card.I have already check card work with step 7 on same computer.
Before APPLICOM CARD INSTALL instead of CP5611 A2(Card change due to applicom not work )
Please help......
thanks
A.A.Mori.
I HAVE B&R POWEL PANEL 400 HMI. THE ISSUE IS HMI NOT BOOTING, DISPLY SHOWING CONTIUESLY (ATTEMPTING TO A BOOT HARD DRIVE....)
53
68
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
65
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
100
121
