S7-400 watchdog
maico
Jun 2012
Belfast
27
Hi All,
how do I set up a watchdog/lifebit between s7-400 and a dcs system, even just to get the watchdog pulse from the s7 would be a start šŸ™ƒ
Thx
The 400 series have what is called a clock byte. You can set this up in the hardware config of the processor.
Then the different bits of that byte will blink at different frequencies and you can either send that or create a frequency divider and create other multiple frequencies.
Hello people, it's been a while... Hoping someone here with patience can help me detect a problem with this code. Its a cyclic state machine...
3,248
I HAVE B&R POWEL PANEL 400 HMI. THE ISSUE IS HMI NOT BOOTING, DISPLY SHOWING CONTIUESLY (ATTEMPTING TO A BOOT HARD DRIVE....)
60
82
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
78
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
108
