S7 search
- Open any block
- Place cursor on a line containing a 'searcheable' element
- Either right click - Go To - Location or CTRL ALT Q
- This opens the Go To Location box
- Substitute the Address contents for the object you want search..
Yeah, sucks I know.....
If you want to search for all occurences of -(P)- for example, view the code in STL to find the related STL instruction (which is FP in this case). Generate the source code for all your blocks and then search the source code for the STL instruction.
Try this.
From the Manager,from the Blocks Folder: Options >> Display (Select Generate) and you got the whole thing. Program structure, Used and I/O Used and unused symbols. Where and how they are used. Double click on selection and it goes there.
Nick
To expand on LD's example, I usually print the whole project to a PDF doc and search that way. Adobe Acrobat versions >=5 have a very good search feature that generates an index of anything you type. This way, I can search on anything at all, from absolute variables to instructions.
Otherwise, the reference list works ok as Nick described. Brenton, what exactly are you trying to do?a
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
258
I have an InTouch HMI that has PID parameters. I need to find what the PID values were in the past. I have backups from the past, but none...
48
5,580
Good morning folks, I'm on a quest to find all of the references to the CurrentUserHasCode function in our project. I have the project...
436
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,034
Hello all, Some of you may be familiar with the RAM searching program for Windows computers, Cheat Engine. You can search RAM directly for...
746
