S7 timers in redundant mode
PLC_talk
Oct 2006
p
50
Hello,
I have S7 redundant system. I am not sure whether S5timer will work in redundant mode. Siemens manual says it doesn't, & only IEC type permitted.
My ladder program is done & tested with S5timers, so it will be a real task to get this shifted to IEC type.
Any one knows a quick work around?
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
118
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
379
I'm writing some alterations to an FPWin program and need to see the running value of timers so I can set them correctly. It's my first time with...
139
Hi everyone I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the...
603
Hi all, I have what is likely not a complex issue, but I am working in Automation Studio and want an accumulating/retentive timer when a...
17
1,929
