Scanner and FT View SE
SMOKE
May 2006
East and West of Kaos
475
I am putting a barcode scanner on a computer running FT View SE.
When I scan a barcode I want it to always fill a string display in SE.
I have used scanners before but always with an SST or PCM card, so the data was always in registers in the PLC. This is my first scanner to HMI to PLC. The scanner will put the data in the field if the field is highlighted I need to point the scanner to the field.
Thanks for any help.
Hi Friends, I have a problem in getting data from a barcode scanner in to my FTView SE scada. Basically, I am new to this and haven't done this...
5,910
Hi - Recently, I upgraded the firmware on a PanelView Plus 1000 to V 5.10.10; I think it was V 4. This meant that I needed to update the .MER...
3,614
I'm trying to develop a program in FactoryTalk View Studio 5.10 for a PanelView Plus 1500. I set up the RIO driver in the Communications tab and...
7,457
Im trying to select recipes on a PV700 plus using a symbol barcode scanner. We have been doing this by scrolling through the recipeplus selector...
1,740
We are currently using a Panelview Plus 700 to store and load recipes to our plc 5000. We are wanting to incorporate a barcode scanner to take the...
6,093
