Schneider and Produce/Consume
I have used EtherNet/IP Class 1 I/O comms extensively with the M340 platform. You need the BMX NOC 0401 module, which supports both IOScanner/ModbusTCP and EtherNet/IP I/O communications (as you say - UDP based). For EtherNet/IP Class 1, It can be either a scanner or adapter, or both at the same time.
The older modules (NOE) support Global Data as a controller-to-controller communications protocol. I always liked it, but seemed to never be used as much as IOScanner (NOE module supports IOScanner/ModbusTCP as well). The newer modules don't have Global Data, so I don't know what the product roadmap is, but I doubt Global Data is on it.
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
56
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
62
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
156
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
83
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
144
