Schneider Momentum & Unity Pro
MATT116
Dec 2009
Dallas, TX
330
Environment
cpu 171 CBU 98090
170 AAI 140 00
170 ADI 350 00
170 ADO 350 00
Unity Pro V8.0
I use RSLogix 500 & 5000 all the time, have also used GE proficy machine 5.9.
with that being said I'm completely lost on how to setup variables for the I/O in unity pro.
Variables & FB instances > IO Derived Variables > under "type" I double clicked > radio button > Catalog > Momentum Unity theres nothing here to pick. shouldn't the modules that I added in my IO bus show up here?:unsure:
or
Should I just create a Elementary Variable "type" EBOOL "Address" %Ix.x.x
Matt you should just create a elementary variable of type Ebool for Digital IO
and Type INT for Analogue variables.
There are other ways of doing this like in excel or a unity IO assigner but this will just complicate things for you now
Thanks, That's what I ended up doing. I was getting confused because I was trying to follow the help file for setting up IODDT but then I figured out that with the momentum having State RAM that's not really applicable.
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
156
Dear Friends, This time I have been assigned a project, where machine has Schneider Momentum 171CCC78010, 171CCS7600 installed. I don't have...
2,700
Hi..I am working on a project involving Momentum PLC 171CCC98030. I am doing its programming in Concept 2.6 SR7 (Demo Version) . I have following...
1,819
I have a customer that would like to move away from Wonderware to RSlogix5000. They currently have Schneider TSX PLCs at their location and would...
2,481
This question is about PLC Schneider Momentum M1 171 CCC IEC-960-30. We have one output element ADO 710 50 attached to the PLC via...
3,284
