Schneider PLC HW config Error
Hossam Azzaz
Oct 2019
Cairo, Egypt
Dear All,
I'm new to programming Schneider PLCs. I've:
CPU: TM200CE40R
DI Module: TM3DI16
DO Module: TM3DQ16R
AIO Module: TM3AM6
Everything was going OK in office (i.e. no HW configuration errors, or no programming errors), but in site, after downloading the ladder user program I found error message of CPU is not consistent with other Modules which are colored in red.
I can't find where exactly the error cause. I need to know.
Thanks.
If you say it was ok before taking to site I assume you had a program in it and it was ok, only thing I can think of is I/O module connector loose, or during installation somebody has fried one or more cards, another possibility is if you downloaded program on site there is an addressing error
Edit: If I remember correctly there are some system registers that might show more detail on the error
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
141
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
176
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
168
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
350
Hi All, We are planning Establish communication between Power Energy Meter (Schneider PM5320) with Rockwell PLC. I am unable to get the Assembly...
769
