Sending SLC5/05 bit to a Westermo GDW-11 Modem??
RPax
Feb 2004
125
Hi, was wondering if somebody could guide me in the right direction. I'am trying to connect an Allen Bradley PLC SLC5/05 to a Westermo GDW-11 Modem.
Basically what I want to do is when a PLC bit goes On, to send or trigger the Modem to send a Alarm text message for remote monitoring. What I'am having problems with is mapping my PLC bit to the modem for the modem to send the text.
I have an RS232 connected on Channel 0 of the PLC. I've looked at other similiar postings on the forum and they suggest using the ASC11 Write command but these are usually for longer messages. Is the same command used for just one bit or do I use a different method. Appreciate any help on this. Thanks
You cannot send a single bit, you'll have to format a word with your modem command bit pattern and send it with the AWT.
Hello, Thanks in advance. How can I send more than 82 characters using AWA or AWT? to Zepra Printer via serial Rs232 communication? Normally I...
768
I am trying to receive status off of a Powerware UPS by sending it an "F" or "Format" command which in turn will give me an 80 character string of...
2,131
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
Hi I need to send a null command down a comms port. But in the crimson software when i used /x00 it coming back "Cannot use null character is...
424
I've been having some trouble figuring out how to get the ip address for the mail relay server, is it something that I need to create separately...
918
