SERCOS. Mixing makes
AJZ
Jul 2003
Ontario
265
Can I use components from different suppliers to setup a servo system using SERCOS? For example, can I use a Allen Bradley 1756-M08SE card with seven Bosch/Rexroth EcoDriveC servo drives and expect it to work fine.
I don't think so. I believe all of the Motion commands are AB product specific. Also when you select a drive under the Sercos module, there is no selection for a Generic Module which implies non AB products are not supported.
This is a screen capture from the Sercos module
pamphlet:
Good afternoon all, We have a carton machine with 7 Ultra3000 sercos drives controlling various servo motors. From what I understand, It has...
447
The CP led indicator flashes red for a split second then back to green. Other two led indicators stay green at all times. I’ve checked...
1,514
Hi you all!!! How do i download the backup in a drive ultra 3000 sercos? I tried to do this through the ultraware software, but it...
1,059
Trying to configure the 2nd drive on this machine. It is being difficult. I have the gains speed encoder data all with good data. when I try to...
1,858
Hi all, My first post 🍻. I'm Jay from the UK. We are in the process of upgrading our hardware to 1756-L83ES, most of our lines use...
1,682
