Servomotor Control using Siemens PLC
sherman4
Jun 2002
46
Hi
I would like to start controlling a servomotor for a very simple rotary machine, and I would also like to use Simatic S7-200 PLC for such purpose.
Does anyone have experience controlling servos with S7-200? is it a suitable PLC for such applications?... Do I require special hardware?
Thanks for your advice.
I've only ever played with a 200 in an existing project, but I bought the s/ware (and associated docs) so here goes -
It depends. What kind of servo drive? Do you already have the PLC?
You can certainly use analog IO for control, you could hang an ASIbus module on a 21 series, the 22 series has a 485 port, not sure if it's only for config purposes but you can add ASI or Profibus to this. If the machine and control is very simple I think it would do the job (21 or 22?) but I'd be tempted to straight out buy a 315-2DP. If you've already got the PLC you'll need Step 7 MicroWin to configure it, the part no. is 6ES7810-2BC02-0YX0. Unfortunately I don't have access to the documentation with my copy right now.
Best of Luck!
hi everyone i need a favour from all the automation gurus at plcs.net well i need a device which is able to convert my PLC pulse output from 20khz...
5,553
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
242
Hi, i need control a servomotor with a plc siemens and obtain all data of this plc and send it by profibus to another plc, 317-2 PN/DP; what can i...
1,934
Hy guys, I want to check if I can use a Siemens Sinamics S120 drives for the below Leroy Somer motors: Leroy Somer Dyneo motor LSRPM 90 SL, 4.8...
2,800
hi goodday to all, i have acopos 1320 as below title my acopos not driven a servo motor,. please help me,.
454
