Siemens S-300 output not coming
tua32683
Mar 2011
Philadelphia, PA
I am sure there is a very simple and logical explanation for this but I can't find it.
My system uses S-300 plc and there is a pointer used to turn on one of the outputs. When I monitor, I can see that output is turned on in the logic but output on ET200S I/O module is not coming. When I force the output it's turning on. Any ideas?
Hello my Freind
Maybe your output is overwriting from a part of your program.
you have to look up your output in all of program and be sure no other place used this output.
hope make sense
Post a screen shot showing the code you are monitoring that demonstrates that the output you are looking at is on.
E.g.
S-300 output is not coming
For some reason my free account does not have a capability to insert images. Attached is the screenshots with the code. When I search for Q100.4 there are no results. When I force Q100.4 output is coming on.
Why do you use a pointer to pass the address in the first place ?
Why not simply put #output_auto on an output pin of the FB or FC, and then place Q100.4 on the pin ?
Apart from that, you have not shown how the address register AR2 is loaded.
I am sorry, my mistake. It is Q4.0 (not Q100.4). But it's the same issue - I can't see this output is being reset anywhere else in the program (please see attached picture).
It's irrelevant, but there is also a part of the code where AR1 is set.
Create a new library named QQQ using Simatic manager, insert an S7 program into the library and then copy all the blocks from your project to the library blocks folder. Archive the library and then post as an attachment.
You have mixed up AR1 and AR2, and why do you load either with 100.0, when you want to point to Q4.0 ?
With all this confusion, why do you even use pointers at all ?
Dear sirs, I have a question about Siemens s7-300 simatic manager, I want to search for marker M36.1 in all blocks of the program, how can I do...
2,017
Hi Quick question. Is there 4mA at the output on the analog card when it is configured in the HW and the card has 24VDC? Or does the output have...
1,422
Hello, I have had a problem where one of the electricians has taken a 24v signal cable out of a contactor and splashed it down onto a phase...
4,658
So I am trying to control the speed of a motor with a Siemens S7-300 PLC. I have an analog input card as well as an analog output card. I am...
7,109
Hi. I use a PT100 ipnut on a SM331 analog input module. To control the temperature in a hydraulic transmission circuit. All I do to get right...
4,265
