Siemens S7-200 Chart Speed / Basics
antsrealm
Dec 2010
Brisbane
207
I am trying to determine a few things in a S7-200 PLC to find an intermittent fault.
With the chart / trend it appears that it is not quick enough to accurately capture all occurrences of a sensor switching on and off. Is there any tricks to getting the trend to capture this info faster.
And is it possible to trend an interrupt event. I would like to compare event 32 to an output coming on to make sure they are operating together.
Thanks.
I would use a latch (set) instruction to see if something came on. This is basically a trap which can be removed after troubleshooting.
Hope this helps,
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
289
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
152
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
196
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
329
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
3,000
