Siemens s7 312c connection to PC
Finn Gevind
Apr 2012
Rudkoebing
Hello
I have a Siemens s7 312C PLC and a IBM PC with Simatic S7 V. 5,4 Sp 3 installed.
I have got a USB / MPI cable from China. But it does´nt work, ( some could think, that was a bad idea to buy overthere, but it was cheap ). I have set the PLC PG/PC interface correctly and i have load the drivers to the cable to my PC. I have also load the Siemens USB driver to my PC.
Are there anybody, there have idea´s to what my problem could be.
I hope you can understand my english, I am from Denmark.
Sencerely regard Finn
Finn,
All the knockoff cables I have seen should be set to a COM port. Check in the Windows Device Manager to see if the cable is using a COM port.
Hi! I have a question regarding ethernet communication with a Siemens S7-312C and 343-1 Lean. For some time I´ve been using the S7NetPlus...
3,300
A client asked me to modify an existing system. It is a Siemens S7-312C compact CPU and a OP3 text display. Now the bitmemory MB0 to MB 60 is used...
2,421
175
142
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
304
