Siemens s7 buffer showing OB121 error
Adnanhamid
Feb 2019
Islamabad
I am facing a plc system fault on plc.when I checked the ddiagnoss buffer it shows
Area length error when writing
Access a dress 432
fc number 83
Module adress 46
Any one suggest how to identify the faulty device.
Open FC83 with the LAD/FBD/STL editor.
From the menu Edit .. Go To .. Block Address.
Specify 46 at the popup that appears.
The cursor will then be at the offending address.
Hello Experts, I would like to seek advise on how or what tag i should use or do to get the PLC diagnostic buffer to know what is the root cause...
5,652
I am currently trying to implement a data pass through solution using a Siemens S7-315-2 DP PLC and an ADF Web Ethernet to Profibus communication...
3,218
I have been given code to put in a machine. I didn't write the code and there is quite a bit in german and STL which I'm not very comfortable with...
10,686
Hey Guys! I've run into a rather annoying little problem with the Siemens AG_RECV block (using a CP343-1) when trying to read data back from an...
4,864
80
