Siemens S7 & WinCC Flex Example
CharlesM
Aug 2005
Arkansas
1,129
Here is a good example of using WinCC Flexible and Step 7 with source code.
Problem
The technological task to be solved is based on a palletizer with 3 axes. The central unit is a conveyor system for the arrangement of 16 boxes on a pallet as follows: axis 1 moves the conveyor system in direction x. Axis 2 is responsible for movement in y-direction. Axis 3 moves the conveyor system in direction z. After gripping of the boxes, positioning is additionally aggravated by two walls which must be passed along the travel path to the target position.
Solution
The automation task is realized by use of a technology CPU and the Technology Template "Simple 3D-Interpolation with cam disks" (Move 3D). In the CPU 317T- 2DP a virtual master axis is used as the core element. The slave axes are synchronously controlled with the help of cam discs. The cam discs for the two axes are read and interpolated during operation.
Here is the link
http://support.automation.siemens.com/US/llisapi.dll?func=cslib.csinfo&lang=en&objid=21062269&caller=nl
Cool, the boss bought me a long awaited new HP Probook Windows 7 laptop with a serial port. My (not that old) Siemens software isn't allowed to be...
19,865
May be a stupid question, but I'll give it a try... For a customer of us we need to use a Beckhoff panel. Because the customer is not happy with...
6,829
Hi I am trying to pack and go a project for the first time. I have a set of MP terminals in spain and need to send files to the commisioning...
9,588
Can some one please help me with the following questions on: Siemens S7 – 300 PLC and WinCC Flex 2007 HMI (Simatic touch panel) Does any one...
12,470
Hi, I'm using some variables of KY data type (two absolute numbers, one byte each, in the range of 0 to 255), if I want to write the two number...
3,264
