Siemens software problem
Elijah58
Nov 2012
Aiken, SC
60
Guys,
Is there such a thing as a free version of step 7 that I can use to write a very small program? I have a piece of equipment that I need to program but it is not something that is worth paying the thousands for software. I will have an HMI to program and all it is going to do is control a vacuum blower that is variable speed depending on the water column. It will be an s7 1200 PLC, KTP600 Basic color HMI,and a 0-10 volt vacuum sensor. All it will need to do is control a vacuum blower to stay at a preset level. Any help would be greatly appreciated. had it been AB it would have been no problem whatsoever.
Eli
Since you need only TIA step7 basic version, just to say that you wouldn't pay thousends. It should be around 500 euro or in that ballpark..
I know Siemens also "rents out" licenses for several weeks, if you need more time than trial will give you.
A Starter Kit will give you everything needed for a good price. Much less than the thousands you think. Different versions depending on which HMI you want. Link.
after about a half day working with a rep from siemens today because I could not get my new tia portal ver 13 software to connect to a plc only to...
4,635
I have just installed Siemens TP designer software version 1.0.0.31 on my laptop. When I attempt to open a known-associated TP file with the...
17,789
Hi everyone, I am an omron plc tec , lately I came across a siemens s7 200 cn plc . Can someone help me regarding the software required and...
26
665
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
503
Hey everyone, I am looking for a version of siemens software to upload and download programs to an S5. I would like a version that runs off of...
482
