Siemens TIA Portal for 1500's - Basic vs Pro
geniusintraining
Jun 2005
SC
8,277
I have a Siemens 1511C that I programmed, I have V16 Pro, anyone know if you can program them with TIA Basic or do you need Pro? I saw a bunch of references in the manual but it just says TIA, I know you need Pro for the 300's and the Basic will program the 1200's but what about the 1500's?
If anyone is using Basic can you see if you can choose the 1500's and 1511c specify
Thank you
Mark
Sorry, sometimes I open a thread to answer, then I get pulled away suddenly, then I go back to click "Post" and then someone's answer is already there.
Me>>>>All the time, then add to that auto correct and I often do not understand what I wrote. Sometimes I have those brief moments of clarity to realize what is about to happen and I quickly close the thread to save myself from myself :D
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
448
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
215
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,530
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,195
Hi, I want to initialise some tags on first scan only. As they are related to wall-clock time, I want to do the initialisation when the PLC first...
1,184
