Siemens TIA Portal - Online "Not compatible"
swedeleaner
Dec 2013
Göteborg
155
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional information. I´ve tried chagning firmware but no luck. What is the problem here?
It´s a S7-1214 DC/DC/DC
When checking Online & diagnostics it says the firmware is 4.5.1. Is this compatible with v4.5 on the cpu?
Software in PLC is V17, I use Tia Portal v.17 Update 6. Is there any more update for the portal?
I've had this problem due to IP address. TIA will attempt to change your IP to be in the same network as the PLC to communicate. For example IP is 1.2.3.4, subnet 5.6.7.8 would require your IP to be 1.2.x.x and subnet to be 5.6.7.8.
Sometimes this just doesn't happen. Rebooting the computer usually solves it, or you can manually change your IP configuration to work.
Thanks for your help guys!
I resolved it, but not the actual problem.
With a blank project, I went to Online—>Upload whole station.
Somehow, that worked like a charm and everything was green and accessible.
As far as i could see, everything was like i tried before.
Well well, these creatures never cease to pull pranks on you.
153
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
234
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
519
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
252
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,610
