Siemens TIA Portal V13 Help
Nan
Jul 2015
louisville
126
Hi, I got some question about Tia Portal...
1. Is there a temporary click button in TIA Portal? Like Fault Rest Button, only find set/reset/reverse bit function.
2. I am using TON under IEC timers, how can represent Timer.TT like in Rslogix5000? And how to reset TON?
3. How to represent AFI, NOT in Tia Portal?
My CPU is 317-2 PN/DP, HMI is TP700 comfort.
Thanks, everyone!
1. Look at "SetBitWhileKeyPressed"
2. Not sure what TT is in RSLogix, but ET is elapsed time?
3. AFI is always false? That would be RESET under the basic instructions I believe.
I did not find "SetBitWhileKeyPressed" Under Button Properties-EVENTS-Click-Add Function, did I look at the wrong place?
.TT means the timing bit indicates that a timing operation is in process.
AFI is always false. Which bit I should use to reset TON, IN OR Q..?
Thank you very much!
.TT is timer timing
Setbitwhilekeypressed is under events>press>addfunction.
To reset the timer before it has reached a Preset, just use .et
If it has reached a preset, and the .Q is high then reset that bit also.
Thanks for replying!
What should I use to represent .TT NOT AFI?
I tried SR and RS, it did not let me find .et, is it the same with reset if I move 0 to .et?
Another question is the LIMIT instruction, is it the same with LIM instruction in rslogix5000? I went through the help..still do not get it..
Thanks for all the replies!
There is another bit associated with IEC timers that is ".RU"
I dont know what it does, but perhaps its functions like a .TT???
You can try it out and see.
They left that bit out of the help file.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
449
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
215
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,531
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,199
Hi, I want to initialise some tags on first scan only. As they are related to wall-clock time, I want to do the initialisation when the PLC first...
1,184
