Simatic OPC Server with PC-Adapter
nels0n
Sep 2009
Aveiro
I need to create a OPC server with Simatic Net but instead of using a CP-card I need to use a serial PC-Adapter.
I know the procedure how to create a OPC server with Simatic Net, because I have created several scada's that communicate with Simatic OPC server but I always use a CP-card (mostly CP5611).
I searched the documentation and the siemens website but found nothing.
In this forum I only found how to create an OPC server with a PC-card.
Can someone tell me if it's possibly to create an OPC server with the Simatic Net using a serial PC-Adapter?
And if it is possible, what is the procedure?
Regards,
Nelson
PS: Sorry my bad english :p
Hi Nelson.
It is not possible.
Kepware's OPC Server do work with the PC Adapter.
Apart from that, the PC Adapter is not suited for a permanent installation. A CP5611 or a CP5621 is not that much more expensive than a PC Adapter, and both are much much better.
If it is not a question about cost, then consider the new USB Adapter (CP5671 I think).
Thanks for the answer.
However, I was forced to change the scada communication with the S3-315 to a Comsoft profibus card.
The main idea of the project is to hide that the machine is controled by a S7-315. The plc was hide in a industrial-pc with the pc-adapter, however if I use the Simatic OPC Server the main idea was not met.
I have another question. The kepserver is free to use in industrial aplications?
Nelson
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,893
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,377
I have a client that has a PC (win7) that runs the Simatic Net OPC server. To this OPC server there are several S7-300 CPUs connected from...
3,113
I have an OPC server running that has unspecified connections to several different S7-300 systems. I'm trying to understand how Siemens is...
7,418
My company has been working with Siemens equipment mainly. I've Step 7 v5.5 installed, and TIA V13 portal installed and WinCC 7.0.3 installed...
1,678
