Simatic Server
userxyz
May 2002
any
2,768
Hello,
We had a power break today and 4 Simatic servers have rebooted.
After reboot all 4 servers are giving an alarm sound...
Anyone knows how to shut up them without throwing them out the window ? (y)
Thanks,
Kind regards,
Combo
Hello,
Thanks,
Kind regards,
Combo
Not sure what's causing the alarm. Is the software beeping, or is it HW?
If HW, could be the raid array checking itself, if that's a thing in your servers.
Possibly also a cranky UPS?
power
Single power,
On the back there is a red button, that was the warning reset button. I pressed that one and it is solved now.
Thanks,
Combo
Do these servers have dual power supplies?
I've had this in the past where if one supply failed it would beep until fixed.
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,885
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,347
I have a client that has a PC (win7) that runs the Simatic Net OPC server. To this OPC server there are several S7-300 CPUs connected from...
3,109
I have an OPC server running that has unspecified connections to several different S7-300 systems. I'm trying to understand how Siemens is...
7,401
My company has been working with Siemens equipment mainly. I've Step 7 v5.5 installed, and TIA V13 portal installed and WinCC 7.0.3 installed...
1,676
