SLC 5/04, damaged EPROM
ppetre
Sep 2002
Hello ,
I am using in my project SLC5/04,L541 and I did a stupid mistake and I damaged the UVPROM.(I removed it from the socle and put back wrong)
(It is the UVPROM(27C256) which I suppose it keeps the basic system operation or firmware - Not the EEPROM backup memory).
I please you if you have a PROM programmer to make a image-copy of this UVPROM for this version or other version of SLC5/04.
If you get for me this file I will burn into a blank 27C256 memory.
Unfortunately I don't have a spare SLC5/04 to make myself a copy of this PROM.
Thank you all !
Hey guys, Well, the troubleshooting continues for the client who got hit by lightning. New CPU has been installed, and is working! That's the...
3,349
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
104
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
116
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
118
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
107
