slc5/05 Error 0257Hex
KEN_KACEL
Nov 2002
NORTH COUNTRY
162
Had an error 0257H which took the system into a major fault. The 02 is the RTD card which had a Memory Lock time out(xx257h). Has anybody ever had this error? It is a first for me. Should I replace the $$$$$$ 8 point RTD card $$$$$$$. It is running right now.
I've had two different SLCs with RTD modules fault for no obvious reason. One occurrence I got the opportunity to examine logic/rtfm and I believe I found some weaknesses in the code that could allow the module to generate a major fault, but I don't recall it being the code you described. It was leased equipment so I didn't change any logic...it happened occasionally (every few hours) for a few days until we found one bad RTD cable and then never returned. I think the bad RTD was freaking out the card and the error was along the lines of 'card failed to respond to a command' or something like that.
In the other case, it was brushed off as a fluke and the tech had already cycled to key switch so I never investigated...
I would weigh the cost of a 2nd occurrence (downtime/waste) against the cost of a new card before throwing parts at it.
I have a packing machine that is running a SLC5/04 for the past 20 or so yrs, that we are upgrading to a spare 5/05. After changing the...
1,361
Wondering if any of you old timers have seen a case where you can download to the processor no problem, but on power cycle: fault, and no program...
2,136
Hi Every One, While Configuring RTD Module in Rs logix 500 i am having error. when i enable RTD channels i get this error file attached name"...
1,635
I am working in a project that will use an AB Panelview 900 connected to a AB SLC5/04 using a 1747-SN Module on DHRIO. I have the digital portion...
1,576
Hi: I have an SLC5/03 faulting (major fault) from time to time due to "50" errors " (A chassis data error is detected on various slots). My...
1,901
