SLC500 /03 block transfer to panelview
paperboy4828
Jan 2006
Upstate, NY
17
Looking for some assistance with a slc500 5/03 to panelview connection. i'm using 1747-SN rev. B (in slot 1) at 115.2k baud, connected to a panelview 2711-TC1, firmware revision 3.
i can communicate and transfer individual bits integers, etc. back and forth between the panelview and slc500... no problem.
i would like to do this with a block transfer. The configuration software for the panelview (PDS.exe, dos version) allows the selection under "communication" - "PLC type" as SLC-500 1747-SN, but then refuses to allow a block transfer configuration, or sends an error message if the application has previously been configured for a block transfer.
Q: is there a way to do block transfer with the existing equipment?
Q: will a firmware update of the panelview resolve the problem?
Q: will a "communication" - "PLC type" selection other than SLC-500 1747-SN work, (say PLC-5/15 integral) even though its not the hardware I have?
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
283
can the slc500 5/05 send a email and text over Ethernet ?
192
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
396
Customer is buying several spare 504 CPU's to have one handy when there's an issue with the ones in operation. Having them on the shelf for years...
2,854
You have to go offline to create the 'Trend' but do you have to download the program to go back Online with the Trend ?
350
