small AC motor 200-300W - but with small diameter
panic mode
May 2003
Toronto, Canada
1,963
Hi everyone,
I'm looking for AC motor, single phase (if it has to be we may consider something else like DC etc but strong preferrence is AC single phase). the problem is that it has to have small outer diameter (it can be long). does anyone have suggestion where to look for something like this?
panic mode said:
Hi everyone,
Couple small questions
HP, RPM, final RPM (if gear reducer), environmental considerations, line voltage, reversing?, what is driven load,
Grainger, McMaster Carr?
Dan Bentler
Would a powered roller work? About 2" in diameter and can run on single or 3 phase or even 24 VDC. I can get company names when I get to work if you want these. Need a little more in specs though.
Also, do you want a single phase VFD to control these (just kidding):rolleyes: .
Hi! I currently have a setup where I have a brushless DC motor that I use to provide a variable amount of resistance/tension to a part which is...
2,244
Does anybody have any sources for small stepper motors or servos? Requirements: 1/4" shaft size or less built in encoder compact 24vdc I have a...
2,865
Hello. Will Connect a small DC motor on plc DO. 24 volt 200mA. Hos to selet diode or varistor for surge protection?
1,802
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
723
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
339
