Hack
Which one does most people prefer. Also which one is more reliable and stable.
SimonGoldsworthy said:Any system that has a Windows based HMI (for example embedded XP, no hard disks) may as well use a soft PLC. Why buy another CPU ?
This type of system will be more suited to (relatively) high volume products that are not modified by end users.
CroCop said:However, with the CLX line, I can do just as much with a regular PLC as I could with a soft PLC.
I'm not sure quite what you mean here. There have always been tools such as RSSql that do an excellent job of that.But can you REALLY do as much with a regular PLC? How would you write your historical data do a database on a remote server?
If I use RSLinx as the OPC server for both the HMI and RSLogix5000, then I can happily program without having to get out another laptop.Program the PLC without getting out a laptop or other PC?
Yup, just add the modules to CLX to your hearts content, and have as many different networks as you like. eg: SST ScannersUse DeviceNET, Profibus, Ethernet, ControlNet, and Interbus IO all on the same controller?
In the real world it just hasn;t worked out that way. The imminent death of the HardPLC has been confidently predicted for as long as I can recall...and yet sales of SoftPLC's is still less than 2% of HardPLC's.Even the most advanced PLC's eventually become dependent on a PC in these days of data requirements. In many cases, it's easier and lower cost to go ahead and use a soft PLC when the system needs a PC anyway for some of its functionality.
I agree on this, but it has to be a very large and demanding process that requires an unusual combination of a very large program, high speeds and complex data integration with other databases to make it all worthwhile. The mere presence of an HMI does not qualify.PLC's have their place in stand alone and less complex systems. PC based control can be a very good solution for more complex systems where a PC is required anyway.
SimonGoldsworthy said:Why buy another CPU ?
