TimothyMoulder
Simon wrote:
>>Which soft plc system have you experienced problems with lately ?
Soft PLC's run 'underneath' windows and are real time<<
VLC, formerly known as Steeplechase. I've wrestled with this turkey for 5 years. I know where-of I speak.
I will use a PC to balance my checkbook or play a video game - and that is it. It may be owing to the choice of software - we've had good success with a Beckhoff TwinCat these past several years - but for the sheer pain, hate and discontent of these VLC machines, they are a misery and an albatross around my neck.
Archie:
>>But can you REALLY do as much with a regular PLC? How would you write your historical data do a database on a remote server? <<
Unitronics. Built-in Database. OPC over Ethernet. 8 installs running merrily as we speak.
>>Program the PLC without getting out a laptop or other PC? <<
If I wished, I could hook up a PC to our Data Lan and program any of these Unitronics V280 controllers remotely, and operate them that way (not that I'd want to...)
>>Use DeviceNET, Profibus, Ethernet, ControlNet, and Interbus IO all on the same controller? <<
Why would I? Modbus covers 99% of my needs, 2 serial, one TCP. With the new AD servo drives, I've got a motion controller going on now. And practically, who needs to talk to that many protocols from one controller anyway?
>>Even the most advanced PLC's eventually become dependent on a PC in these days of data requirements. In many cases, it's easier and lower cost to go ahead and use a soft PLC when the system needs a PC anyway for some of its functionality.<<
In a word - hooey. Anything you thought you saved in hardware will be devoured shortly in frequent repeated crashes and upgrades when the hardware you bought six months ago is rendered obsolete. We spent a fortune to upgrade these VLC PCs to XP - I could have simply redone the control system for less, but didn't have the time.
>>PLC's have their place in stand alone and less complex systems. PC based control can be a very good solution for more complex systems where a PC is required anyway. <<
I have been at this 14 years now. I have not yet EVER seen a process that a PC could have done, but a PLC could not. As PhillipW said earlier, even with my little M91 controllers, I can go with a distributed architecture to share the load. With Beckhoff IO and AD servos, I can create an entire system with multiple motion axes and hundreds of IO points, on a PLC costing less than $600.
PCs have their place - on the manager's desk, playing SOCOM, not on the production floor, playing with your livelihood.
TM
Archie:
TM
