Software for MicroLogix1200
SirCharles1
Jun 2013
Hamilton, Ontario
22
Good day all. What is the exact software that is required to program the MicroLogix 1200. I know it is RSLogix but what type. They have professional edition, starter edition etc.
Both will work, but Pro cost more and has more features, here are the current version they have
This may help... its a little old but I think still good http://www.software.rockwell.com/download/logic/rslogix/misc/rslogix r6.0 comparison.pdf
PLC Design Software:
9324-RL5LDRENE: RSLadder 5
9324-RL0LDRENE: RSLadder 500
9324-RL5700NXENE: RSLogix 5 Professional, ENU
9324-RL5300ENE: RSLogix 5 Standard - CD
9324-RLC700NXENE: RSLogix 5/500 Professional Bundle
9324-RLC350ENE: RSLogix 5/500 RSLogix Emulate 5/500, Bundle, CD
9324-RLC300ENE: RSLogix 5/RSLogix 500 Programming Bundle - CD-ROM
9324-RL5350ENE: RSLogix 5/RSLogix Emulate 5 Bundle, CD
9324-RL5300NXENE: RSLogix 5/RSNetworx Standard. Bundle, ENU
9324-RL0700NXENE: RSLogix 500 Professional
9324-RL0700NXENF: RSLogix 500 Professional Edition Offline/Online Programming
9324-RL0300ENE: RSLogix 500 Standard CD-ROM
9324-RL0300ENF: RSLogix 500 Standard Offline/Online Programming
9324-RL0300ZHE: RSLogix 500 Standard CHINESE
9324-RL0300ZHF: RSLogix 500 Standard CHINESE CD
9324-RL0300FRE: RSLogix 500 Standard FRENCH CD
9324-RL0300DEE: RSLogix 500 Standard GERMAN CD
9324-RL0300ITE: RSLogix 500 Standard ITALIAN CD
9324-RL0300PTE: RSLogix 500 Standard PORTUGESE CD
9324-RL0300ESE: RSLogix 500 Standard SPANISH CD
9324-RL0300NXENE: RSLogix 500 Standard; RSNetworx for ControlNet
9324-RL0100ZHE: RSLogix 500 Starter CHINESE CD
9324-RL0100ENE: RSLogix 500 Starter ENGLISH CD
9324-RL0100ENF: RSLogix 500 Starter Offline/Online Programming
9324-RL0100FRE: RSLogix 500 Starter FRENCH CD
9324-RL0100DEE: RSLogix 500 Starter GERMAN CD
9324-RL0100ITE: RSLogix 500 Starter ITALIAN CD
9324-RL0100PTE: RSLogix 500 Starter PORTUGESE CD
9324-RL0100ESE: RSLogix 500 Starter SPANISH CD
9324-RL0350ENE: RSLogix 500/RSLogix Emulate 500 Bundle, CD
9324-RLC300ENF: RSLogix 5-500 Standard Bundle Concurrent Edition
In case you missed it, it is the "RSLogix 500" versions that can be used with a Micrologix 1200 PLC. The RSLogix 5 versions are for the PLC-5 models.
RS 500 - micrologix , pico , slc 's
RS 5 - PLC -5 system
Rs 5000- compact logix , control logix , Soft logix
Hope i am right if wrong pls correct
Regards,
Nelliyan.G
As noted above you can use any RSLogix500 package. But you can also use RSLogixMicro software which is substantially less expensive (~$150.)
The free RSLogixMicroStarter will not work as it only supports the 1000 and 1100 :(
We are so bad! Are our answers too exclusive, or is the PLC world simply complicated by each brand's marketing strategy?
What is the exact software that is required to program the MicroLogix 1200?
The exact answer is that there is no ONE "required" RSLogix version to program a MicroLogix 1200, but several possibilities. The choice depends on YOU, what capabilities you need compared to how much you want to pay.
I would really recomend you to go into Micrologix 1400 instead of 1200, because its almost the same. But the 1400 has a Ethernet Port (for communication and programming), and a little display with keys (that helps a lot in case of problems and you are no on site, for viewing fault code, reload program from memory card).
If you just want something cheap to learn, then the Micro800 (830 or 850) is a good option. It has free programming software.
Best regards,
crawler009
Hello all, I am an Industrial Electrician, and deal with a little bit of everything including PLC troubleshooting and programming. When I started...
111
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
110
124
Hi, I'm currently having issued with a PowerFlex 252. It was working fine last week, and suddenly decided to stop working. When I go into...
121
