SSD Drive Software - NEW
504bloke
Jan 2005
Down South
2,721
Anyone using CEDlite for programming SSD drives (650V, 690+, 591P etc etc) may like to know that DSELite (used to be for 890's only) now supports all ssd drives (690s, 650s, 591 etc etc)
If you have already got DSELite installed then install the new version (2.03 or later) from here but note when you click on your old shortcut that your old version of dse will open up - the install doesnt re-do the shortcuts and the old app is still current so youll need to do this manually.
Hi, thanks for the tip, is there any advantage to using the later software? I find that the old CE Lite not showing 'online' data was a pain, having to keep updating from the drive. Does it import CE Lite files (old backups).
I will play with it when i get some time but i have a full schedule for a few weeks
Cheers.
Cheers.
Yes it opens old CEDlite files but when you save it in DSELite it can then no longer be opened by CEDLite. I havent had a good play yet but believe it will show online data in a data monitor, it also autoconfigures baud rates etc to match the drive. CEDLite will be dropped soon i guess, it was always an old dos/win3.1 style dinosaur anyways!!
Dear all, we have a couple of SSD 637 servo drives that need to communicate trough easyrider. On the parker website you can download easyrider...
524
I am hoping that maybe someone can help me. We currently have an inherited mold take out device from Germany. It has a single axis and utilizes a...
1,388
Can we install a solid state hard drive SSD for a Siemens field PG M3 6ES7715-1BB00-0BE1 ? Which type of SSD could be installed inside this PG ?
3,279
What is the best velocity command resolution I can hope to get with a Parker/SSD 890 drive receiving a velocity command from a plc over...
1,596
Does anybody have any knowledge of oddities with the SSD 890 AC Drives? Both compact/bookshelf, and monstrous stand alone ones have the habit of...
4,923
