String dollar Sign $$$$$$$
latchpad
Nov 2018
Michigan
is there a way to put a single dollar sign in front of a string in Studio 5000? I am trying to do that but the reference string i want to use gives me an error if i try to put only one. I am trying to control a device via socket messaging and it required a 4 byte hex syntax with $ infront. for example $0E$DA is the string i need to send it. Ive attached the picture of the error message it gives me.
$$ will give you a single dollar sign in Studio 5000 string.
It's actually at the top right corner of your screenshot.
You can also type $24 that represent HEX ASCII code for "$"
If $0E$DA is the only string you need to send, you can just enter that into the string tag. It will be red when you put the $ in, but when you put the next two hex characters in, or the next dollar sign as Contr_Conn suggested, it should turn bold.
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
255
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
173
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
141
As the title says, I'm using CCW with a PV800 (and Micro850). I've made a scheduler in which a user can choose a month, day (1-31), hour (0-23)...
521
