Studio 5000 logix emulate
Crkondekar
Feb 2019
United States
I am getting an error when i create a new controller. The controller has a red cross and an error saying controller error. When I add a virtual backplane in linx classic the controller slot is not detected.
I have a screenshot in the attachments. Any help ?? :unsure:
I've found that I had to restart RS Emulate, and delete the module... either restart first and delete, or delete first and restart, until it goes away. Then add a new CPU again after it's worked out. It's finicky software.
You also have to make sure the slot number in your project matches the slot number in the CPU. In the above case, it's Slot 2.
Hi. I solved this problem. It was happend probably because you have LogixEmulate5000 version 28 or lower and at the same time you have Windows10. I had same problem and contacted Rockwell support and he said to me, that it is probably by this. I downloaded Studio5000LogixEmulate from their web site v.33 and now it is function with Studio5000 v.33. That problem with red cross is to version 29 LogixEmulate. From version 30, it is solved for Windows10. It is possible, that it will be not function because you have different problem.
I found LogixEmulate by expression "Emulate"
(y)
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
139
Hey Guys, I am looking for a cr@cked version of Studio 5000 Logix Emulator V28 or Rslogix5000 V21, which will work with my current emulator...
284
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
480
I have installed Studio 5000 Professional version V36 a time ago and installed today Logix Emulate V36. I have a exsisting PLC program, but...
740
Hi all, I'm going to start programming a 1756-L73 and I'm still waiting for the full Studio5000 to be able to start at it in earnest. But I...
436
