Studio 5000 (V32.03) Ladder Window display can not be edited
ShhhhhLorz
Mar 2024
Denver
Got a repaired laptop back from warranty and loaded it up with all my software, unfortunately with my version V32.03 Studio 5000 I cannot change the ladder window background color. Its currently set the bright white default not matter what color I choose and accept changes. I've tried loading different versions of studio but can't seem to get it to change to something less distracting.
Does anyone have a fix for this or point me in the right direction? RA where no help. Programming with a white background gives me a headache fairly quickly :(
I tried it in my v32.02 and it worked. It carried over to v34 as well. If you have another version installed, I'd try changing it there too. Couple of other things to try:
1) Press and hold left-Ctrl and left-shift while opening the software. Hold buttons until it finishes loading all the way. That's supposed to restore all default settings. Then try to change it again.
2) Right-click on the executable and "Run as Administrator".
Sorry, I don't have any other suggestions.
Thanks for the suggestions, I did try them with no luck but I ended up figuring it out. Our programs are protected and are view only, and the source code file that the program was looking at was empty. I configured the security settings to look for the actual SC file and for some reason the colors and fonts started working correctly again.
That's.....really crazy. I wouldn't think that source protection would affect the background color, but there you are...
<sigh>
Also: thank you for posting the solution. That will probably help someone in the future.
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
148
Hi, I am having issues with Studio 5000 v32.02 and connecting to a 523 PowerFlex drive via Ethernet. My network consists of a 5380 CompactLogix...
1,781
installed v32 on server 2016 and when i open studio 5000 it freezes on the logo screen any ideas to why
1,682
I am a big fan of developing in Logix Emulate when I don't have access to a live PLC. That said I am running into an issue with not being able to...
1,544
This forum post I found seemed to reference the same issue, and if posts were still allowed on that thread, I might make an account there to post...
5,790
