Studio 5000 Version Recommendation
J E
Jan 2007
Louisiana
53
It has been a couple years since I created a new ControlLogix project, and apparently we are now on version 28! :eek:
Why do we need so many new versions? And more importantly, are there any issues with the newer ones that I should be concerned about?
Ask your customer if they got any preference. Keep in mind that L6X processors can only go up to V20 and L8X supports only starts with V28, I think.
From what I learned, there are only minor differences after version 24 and anything higher have more to do with additional device support and not any major feature or functionality change. Again, based on what processor you have to deal with, that may narrow your option down.
This is very much a summarized version and from memory so I may have forgotten something, if so I apologize:
V20: Last Version of RsLogix before the Transition to Studio 5000. Last Version to support L6x ControlLogix controllers and the L23x, L31, L32x and L35x CompactLogix Controllers. There are 3 versions of V20, V20.00, V20.03 and V20.04. Use V20.04 if you are using version 20.
V21: Introduced Studio 5000 and support for the Kinetix 5500 servo drive. Note there are two incompatible versions of V21, V21.00 and V21.03. You can move from V21.00 to V21.03 but not back. The change was a security issue.
V22: Does not Exits, only an internal Release within Rockwell.
V23: Basically released to solve the incompatibility problem of V21.00 and V21.03.
V24: Lots of new features including Local Parameters that can be shared between programs, Compare and Merge Tools, Logical Organizer etc.
V25: Does not Exits, only and internal release within Rockwell.
V26: Introduced support for Kinetix 5700 servo drive & Licence based Source Protection.
V27: Introduced View Designer to work with the PanelView 5500.
V28: Introduced support for the L8x series of processors.
If you are going to do a new project then I would use V24 or newer. The new features in Version 24 are very good. Unless you need to use them for the new Hardware support I don't see much advantage in versions 26-28.
Regards
Ian McDonald
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
409
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
486
Hi, Im trying to install Studio 5000 V32. I've installed the previous version in order from v20 to v31. Whenever I run the setup file i got this...
1,425
Hi All, While building the offline project for CLX 5580 with 1756 Rack I/O, I noticed that there is a field for "Series" and "Version" for some...
712
Good Evening , I purchased Studio 5000 Standard a few weeks ago . I know Studio goes down only has far has version 20. I need to go down to...
4,705
