studio5000 day of week
This is the subroutine where all the heavy lifting is being done. The main routine has the GSV.
This is a sample program that is probably included with existing Logix software. So it should be easy enough to locate if you have RSLogix/Studio 5000. I just searched "DayofWeek" on my machine and it found it.
OG
Perhaps OP is using one of the seven Day-of-Week tools found on the RA site (here)? Or are they using the sci-math-faq formula (e.g. here)?
From what I can see, all of them use year, month, and day. So when that day value changes is when the calculation will change.
If I had to guess with no other information, I would guess that the GSV call is probably getting yr/mo/d from WALLCLOCK/DateTime**, when it should be using WALLCLOCK/LocalDateTime**. LocalDateTime appears to be correct, so perhaps the CSTOffset is -7200E6µs (i.e. -2h).
* i.e. the base time, ideally UTC or GMT? but it could also be EST with a CSTOffset of 0.
** i.e. the Georgia, USA-appropriate local time i.e. Eastern US i.e. EST/EDT
We do have other information:
  • One of the images, presumably of the AOI currently in use, makes a GSV call to WALLCLOCKTIME/DateTime, which supports the idea above
However:
The day of week program started changing day of week 2 hours early. It changes at 10 P.M. instead of 12A.M. Just started this year.
So it was working correctly before. Which raises the question of what changed i.e. why does the day-of-month change 2h earlier since New Year's?
Also:
I have a GSV with local date time so maybe it is causing a conflict in my logic.
Which seems to suggest WALLCLOCKTIME/LocalDateTime is in use.
The only way to be sure would be to see the online (real-time) values, including .Hour, of the TestDateTime structure in the same picture with the Windows clock at lower right.
By the way, a much simpler formula would be to
  • get the the µs since 1970 local time i.e. (WALLCLOCKTIME/CurrentValue + WALLCLOCKTIME/CSTOffset),
  • divide by 86400E6 (µs per d) with truncation to get days since 1-Jan-1970,
  • add 4 (1-Jan-1970 was a Thursday), and finally
  • reduce that modulo 7 to get the current day of week number (0 => Sun through 6 => Sat).
That would be messy, I think, for CompactLogix as they do not have LINTs. But it could be done with DINT pairs.
Hello all, Hope you all are having a good weekend. Can someone share me an opinion to which software should i get. We have around 5-6...
161
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
185
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
194
I am not sure if this is possible but if there is a way, you guys would be the ones to know. I am currently working on a project where we are...
276
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
424
