Studio5000 early Expiration problem
jaden
Sep 2009
Pleasant Dale, Nebraska
304
My Studio 5000 would not start RS5000, saying my 7 day grace period had expired. I checked and found the software expiration was 6 months from now.
RS500 in the same package works fine. Anyone have similar experiences?
Use FactoryTalk Activation Manager to see what's going on with the licence. It may have already expired sending you back to the Demo on Studio.
**EDIT: If so, I'm sure your local Rockwell distributor/supplier can get you a temporary licence to get you out of trouble.
Does the Studio 5000 serial number in Help>About match the serial number in the activation manager?
I have never come across this. Studio 5000 is so easy to program i am usually done before a week is out, and never have to revisit the code.
That said, find out what bit of hardware the licence is tied to. It is probably missing or turned off, eg wireless adapter MAC address.
Either rehost it, or fix the device.
I hope this is at least half helpful
Mine does this fairly often when i have multiple different versions of RSLogix5000 and Studio5000 open. It also does not release the license after all my Logix windows are closed. A reboot fixes it.
I have found the "Refresh Server" button on the Advanced tab of FactoryTalk Activation Manager helpful for fixing license inconsistencies, though I have not experienced exactly what was described in post #1.
I have discovered that last year's activation is still present on the computer, and it's serial # is the one shown, not the one from the latest activation.
Strange thing is, it worked for 6 months after new activation.
Now, I can't delete the old activation.
Aha. Maybe Logix is trying to take the old activation. Whether that's because the new activation is being "held onto" by some other instance of the software that didn't shut down properly (or something), or because Logix just has it's knickers in a twist and is playing dumb, I guess we don't know.
I do remember that when I put my new activation on last year, it took me a while to work out how to get rid of the old one. It wasn't causing me any problems, I just have OCD :ROFLMAO:
Unfortunately, that was nearly a year ago, and I've forgotten. Which reminds me, I need to follow up this year's renewal...
If rehosting is not an option, perhaps try browsing to the folder where the .lic files reside, and deleting the old one (obviously, double check which one is which first!). Then refresh your server, refresh your activations, restart Activation Manager, restart your PC, stand on one foot, spin around counterclockwise twice and pray to the gods of Rockwell Activations, and see if that helps your situation at all.
If it helps, I've got several old activations (Toolbox annual subscriptions) and it hasn't had any effect on the operation of any RA software that I've witnessed. I haven't been able to delete the old activations either but I didn't pursue it beyond the "normal"steps.
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
154
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
161
I am not sure if this is possible but if there is a way, you guys would be the ones to know. I am currently working on a project where we are...
225
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
368
The day of week program started changing day of week 2 hours early. It changes at 10 P.M. instead of 12A.M. Just started this year.
22
2,679
