Studio5000 V26.01 Export - NOT
Aabeck
Feb 2013
Detroit
1,860
I just got ver 26.01 installed & running after a lot of help here and an hour on the phone with Rockwell. Studio 5000 Full.
I opened some projects and successfully converted them to v26, they open, verify and save OK.
However, I cannot export any AOI, UDT or routine - it just goes busy for a few seconds then wakes back up, never popping up a Save box. The Import routine, AOI and UDT does work.
My install of V20.05 does export, as I have all my AOIs & UDTs and some routines saved in a folder to import later.
EDIT: I am running as Administrator with Windows Vista compatibility.
What operating system? I’ve never been able to get V26 to run successfully on windows 10. I can only get V26 to run correctly on windows 7.
Windows 10 Pro using Windows Vista compatibility as Administrator - just edited my post as you asked.
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
167
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
172
I am not sure if this is possible but if there is a way, you guys would be the ones to know. I am currently working on a project where we are...
230
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
383
The day of week program started changing day of week 2 hours early. It changes at 10 P.M. instead of 12A.M. Just started this year.
22
2,701
