Studo 5000 V32 - Rename AOI - Error Already Exists
theColonel26
Feb 2014
West Michigan
785
I am trying to rename an AOI Definition and I keep getting the Error "Failed to Modify the instruction. Already Exists"
But there isn't another datatype/instruction with the name I am trying to change it too.
I even tried assigning it a name of random letters and it still does it.
I have tried renaming other AOIs and they work fine.
Do you have a tag by that name? I think (Unsure ATM) that AOIs, UDTS, Tags, cannot share the same name. Its got to be unique.
Just tested that
I was able to create tags with the same names as UDT's & AOI's.
I was able to create an AOI and a UDT named the same as existing tags, BUT:
I could not create a UDT or AOI named the same as an existing AOI or UDT - that faulted.
However, the line "I even tried assigning it a name of random letters and it still does it." seems to me to indicate the AOI is locked in the properties or something (Like a Windows "File in use" error that won't go away until a CHKDSK is performed.)
sorry for the late reply. took me a while to get back to this project.
So what I did was I exported the AOI type then reimported it, in the import config I changed the name to what I wanted it to be. Then I went and changed the references to that type to the new type name.
I could then delete the only one. ONLY Now I can't rename it again. I don't need to because it has the right name now but it is really strange.
Oh I just figured it out.
Apparently if you use an AOI inside another AOI it gives you this error. I was using this AOI in side another one. :doh2:I hate AB
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
347
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
125
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
129
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
80
Hi all. I want to ask what may seem a stupid question, as I have a project to send live data to a Yeacode line printer which will print meterage...
211
