Studo 5000 V32 - Rename AOI - Error Already Exists
theColonel26
Feb 2014
West Michigan
786
I am trying to rename an AOI Definition and I keep getting the Error "Failed to Modify the instruction. Already Exists"
But there isn't another datatype/instruction with the name I am trying to change it too.
I even tried assigning it a name of random letters and it still does it.
I have tried renaming other AOIs and they work fine.
Do you have a tag by that name? I think (Unsure ATM) that AOIs, UDTS, Tags, cannot share the same name. Its got to be unique.
Just tested that
I was able to create tags with the same names as UDT's & AOI's.
I was able to create an AOI and a UDT named the same as existing tags, BUT:
I could not create a UDT or AOI named the same as an existing AOI or UDT - that faulted.
However, the line "I even tried assigning it a name of random letters and it still does it." seems to me to indicate the AOI is locked in the properties or something (Like a Windows "File in use" error that won't go away until a CHKDSK is performed.)
sorry for the late reply. took me a while to get back to this project.
So what I did was I exported the AOI type then reimported it, in the import config I changed the name to what I wanted it to be. Then I went and changed the references to that type to the new type name.
I could then delete the only one. ONLY Now I can't rename it again. I don't need to because it has the right name now but it is really strange.
Oh I just figured it out.
Apparently if you use an AOI inside another AOI it gives you this error. I was using this AOI in side another one. :doh2:I hate AB
I'm trying to compare strings in Studio 5000 on an Allen Bradley 1769-L33ER and came across this weird incorrect string comparison. Neither of the...
201
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
151
Hello everyone, Wondering if anybody can help me with this: I have a CompactLogix processor running a little robot cell. Every 200 cycles...
188
Hello everyone, I'm new here, I hope someone can help me. I've been trying to install EDS files to my Studio 5000 with the EDS tool installer but...
134
Hello all, Hope you all are having a good weekend. Can someone share me an opinion to which software should i get. We have around 5-6...
175
