tech
samoil
Feb 2006
indiana
22
:pI have PanelView monochrome 550 touch screen.Works fine just does not have ilumination and I can's see the screen clearly.
Any advice?
Is this something that just happen,was it working ok?
There is a back light setting under PV550 advanced tab in terminal set-up.
On the back of a PV 550 is a cover over the lamp that provides the back light.
This back light plugs in
I had to change a couple of lamps in earlier days until I altered the backlight setting to turn off after 10 mins of inactivity.
The lamps are not a cheap item
Well, I started to work there recently and this is situation I just find. Which cover I have to take of, whot I do for easy replacement?!How I can program to turn off in 10 or 15 min?
Thank's again
The cover over the lamp slides off ,its tight and at first look its not obvious that it slides off.
Under the configuration screen there is a screen saver or similar tab that allows you to set a timed period to turn off the lamp
I think its the left and right buttons at the same time that gets you to the configuration screen.
Good Morning , I installed an AC Tech ESV 1 HP Drive on a small bucket conveyor. Before it had a DC Motor on it . It now has a Baldor 1 HP...
214
Hi, I have an older Kohler Generator/ATS controller that has a Schneider Electric (Modicon) Momentum PLC and has a Advantech HMI. I assume this...
714
Hi all, I need some local help to upload the Crimson program from a G310 Red Lion HMI. It cannot be easier than that. The thing is (for reasons...
1,065
Basically, I need the latest version of the Rockwell "PF525_Faceplate_AOI" THe one I have is v1.0 from 2018 I went to the PCDC and typed...
1,572
German and English Grüß euch, ich hab im Forum zum Thema Panel download leider keinen Beitrag gefunden und möchte euch folgendes fragen: Ich...
1,112
